Threads too long for fittings
7 Jan 2009
Germany
I have a problem with some fittings not fitting.
I have 1/2 inch fatboy style barbed fittings but the thread on them to join is very long, so long that when screwed into angle fittings the O-ring doesn't seal.
Is there any way of getting round this without purchasing new fittings so I can use my current fittings with the angles.
The angles are standard EK ones and I believe the barbed fittings are also EK (possibly old style)
Cheers
