- 6 Nov 2006
- Lowestoft
Okay dudes and dudettes (if there are indeed any ladies on this board), I have an idea I would like you to pull apart.
I'm planning on building a BIG water cooled rig (so space not an issue) and was thinking of using a car radiator to provide HUGE heat dissipation (and lots of water for thermal capacity). Thing is, the hoses to these rads are very big. So I was wondering, would it be possible to have three branches, rather than a single loop? Branches would split shortly after the pump, one going to CPU, one to GPU and one to northbridge. The branches would then rejoin at the rad through some sort of custom 3-way cap sort of thing.
If you're thinking 'Why?', the answer is it would look cool.
If anyone has tried this, has any theories as to how well/badly it would work,problems etc. Please let me know.
P.S. the pump would be a central heating pump chucking out around 2000 l/hr
Cheers guys
Cheers guys
