Three dropping data signal
18 Oct 2002
North Wales
Hi,
I have an issue which I suspect to be network related, but could be device related I guess. Basically the data signal will be lost and will not return until I restart the phone.
i.e. I will have voice signal, but no data. Turning mobile data/flight on/off does not restore the data connection. But if I restart the phone I'll get data straight away.
If I use another SIM card in the same phone, I do not experience these issues, even if I enter an area with no signal - I will get data again as soon as I get signal again.
I'm wondering if anyone else has had these issues, I don't really want to leave 3 and signal is actually ok for me - aside from this issue.
Send their Twitter support a message. They will check things over for you.
( may tak a few days for them to reply though)
contact them and ask them for a new sim. that might sort things out for you. most people have difficulty in receiving signals indoors with three usually.
Speak to them again. They are usually quite helpful when it comes to this kind of thing.
Yep this week, first time it's ever happened for me and I have had to restart the phone each time. IP5s. If it does it a few more times I will give them a ring.
