Permabanned
- 28 Dec 2009
- london
I have an old hd3850 and I currently have two samsung 19" and will be getting a u2412m shortly. The 3850 has two dvi ports on it.
Two questions:
Will I be able to to buy a monitor splitter cable and run two samsung monitors off one dvi port? I remember using a splitter at one of my jobs too use two monitors off one vga port but not dvi and they were small monitors as it was years ago.
Apparently the 3850 supports 1920x1200 but do you think I would get better use of the monitor by buying a new graphics card? What is the minimum that you would recommend for the dell u2412m monitor, to get the most out of it.
http://www.powercolor.com/Global/products_features.asp?id=67#Specification
Two questions:
don't need more drives.
