On my way back from work yesterday, I found that my bike was revving quite a bit on right hand corners but fine on lefts. After a bit of digging about, it seems that the throttle cable is the culprit, possibly pinched on something or a bit tight/worn. Is there a visual clue to use to determine if the cable just needs adjusting or replacing?
Bike is a 99 Bandit 600 and it's done just over 6k miles if that makes any difference...
I have seen people mention lubricating a throttle cable I've not got the faintest on how to do things like this...
Cheers!
Cheers!
