Hey folks,
Just looking for a bit info here and to see if a mates correct.
Recently I have noticed when the bike is up to operating temps and I open the throttle to give it some welly there is like an initial flat spot then you can fell it pull. close throttle and pen it does it again.
Mate said it is possibly the rubbers on the carb's are perished and letting in to much air which is messing up the mix.
Is it possibly this or something more sinister?
Bikes 1986 Honda VFR750FG, Serviced within last 2000miles (Including spark plugs) new chain and sprockets (Not sure if this matters)
Any help would be great cheers.
Edit: Forgot to say It also received a new Battery and Regulator/ Rectifier within the last 1k
