Hi All I have been reading about the throttling the BT Infinity & VM etc do on there broadband ,but what i want to know is if there is a way around this ,if so what ?? and i don,t mean go to an isp that doesn,t do this either
any views thanks ![Confused :confused: :confused:](/styles/default/xenforo/vbSmilies/Normal/confused.gif)
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
I don't think you can get around it. They throttle you on peak hours if you download to much and usually stays throttled until 12AM. (From what a friend told me!)
yeah thats what i thought , but can you use a free VPN Service i,ve seen on the net ?? do they work ?
You'd need a very high-bandwidth VPN to use anywhere near your line speed anyway on fibre, not sure what that might cost.
