Thrustmaster GTE Wheel part help
26 Oct 2014
Hi Guys
Got myself a rim only for a thrustmaster GTE. I am looking to buy the rest of the wheel ie button plate and shifters.... do they all come as one unit and if so what is the correct term for this?
Generally TM wheel add-ons come as part of one unit. If you only have the steering wheel you will essentially need their button box to attach it to a wheel base.
Unless you want to fully DIY, this may be what you're after. I used one before I made my own wheels/shifters/enclosures and it worked well.
Or maybe you want something like this or this? In the case of the last two, you'd need an adaptor to attach it to your wheelbase.
Premade adaptors here, or get one of these 3D printed.
Also, have a look around here and see if there's anything that fits the bill.
ED; or do you mean that you somehow have a GTE rim and need the button/shifter enclosure that's meant to come with it? If so, I think you're out of luck unless you can find a used one.
