It's the fine-pitched ones, I'd guess these would do :http://www.overclockers.co.uk/showp... Thumbscrews 6 pack - Aluminium Cases (Type 2)
Got some on my desk in front of me, they are definitely the fine pitched ones.
Just looked
Indeed they are.
Only thing is the ones you linked say they're case screws...Indicating they may be the tape for side panels...
Although on your average case the PCI brackets are held in with course screws anyway.
****Just read the Aluminium part, so I don't know to be fair.
Ah well since ive got free delivery I ordered one pair lol, if they're right i'll order another 9![]()
I believe they're correct...Someone was advertising them on the bay as fine thread so hopefully yeah
Either way, standard cd-rom type screws will fit if they don't.
