Thumbnail creator program
Permabanned
22 Apr 2007
I'm looking for some software (free, ideally) that can make thumbnails of a whole load of images for me quickly (like batch).
Whats available and what do you lot use?
I haven't used it but am planning on making some thumbnails, but a quick google found this:
http://www.fookes.com/ezthumbs/
Easy Thumbnails is a popular free utility for creating accurate thumbnail images and scaled-down/up copies from a wide range of popular picture formats. An elegant interface makes it a snap to find your images and select them for processing individually, in groups, or in whole folders, using a simple file selector and built-in image viewer. You can use slider controls to rotate images and adjust their contrast, brightness, sharpness and quality, and check out the results with the built-in viewer.
Key Features
* Scale images up or down in batches
* Eleven resampling filters, including Lanczos3
* Sharpen soft images from digital cameras
* Real-time preview of target image
* Supports the new JPEG 2000 image format
* Preserves EXIF data in JPEG images
* Supports lossless JPEG rotation
* Free software producing quality results
