I'm looking to replace my almost 7yr old 3rd generation i7-3700 PC with the following:
I don't play games so want to use the motherboards onboard graphics. This is where I need some help...
The Gigabyte motherboard above has two Thunderbolt 3 USB type C ports on the motherboard which, form what I understand can be used with a monitor (or as a video output). Is this correct?
I don't want to use the onboard HDMI as it only supports 4k@30hz but the Thunderbolt 3 supports 4k@60hz.
Also, can I use a Thunderbolt 3 to HDMI cable with the motherboard/screen to get 4k@60hz?
Thanks for eny help.
- Inter Core i9-9900K 3.6GHz (Coffee Lake) Socket LGA1151 Processor - Retail
- Gigabyte Z390 Designare Intel Z390 (Socket 1151) DDR4 ATX Motherboard
