Hi
My bike (2005 Honda Hornet F4 600cc with ~30k miles) has developed a ticking noise when I'm in second gear at fairly low revs (around 3-4k) so it's noticeable when pulling off or cornering at low speeds.
My first thought was the chain, but when I pull the clutch in and roll everything sounds ok.
Another thing I noticed today when my brother and I swapped bikes was my chain bouncing just when cruising along. It's a pretty old chain, but still within the limits on the adjuster and the sprockets look good. Tensions are all good as well. Would it just be an old chain causing that?
Thanks.
Thanks.
You might also need to apply some rear brake to give the engine something to work against or it'll be a bit jerky.
