Tidy 3x8 Pin cables
19 Dec 2017
I've just changed from a 3090 with a nice neat 12pin cable to 6900xt with 3 stiff, ugly 8 pin pci-e cables which not only look bad, but make it difficult to get the side of the case on as well as sit precariously over the intake fans at the bottom.
Does anyone make a good solution for 3x8pin pci-e? I'm just about to fit a Asus ROG Platinum PSU, which I presume will use the same cables as the Seasonic it's based on?
cable extension and comb? the bitfenix cable kit comes with 2 cables and you can get another seperately. the kit also has a lot of wire combs. the combs are 12 cables in a row so it should work quite neatly with 3x8 pcie cables
Computer Orbit will make you a custom 3 x 8PCIE pin cable using AWG 17 Gauge wire.
Heres the one he did for me
3 ways in order of cheapness
black cable tie
comb kit eg bitfenix
custom cable
ive honestly used cable ties in some places and u can hardly see
