Tidy case - How do you do it?
7 Feb 2004
When I look at some of the cases on show I think where are all the wires, my computer looks like some sort of spaghetti disaster compared to these.
Do you have any advice on tidying it up?
Here's a picture of mine, Look where all the wires go....Thats the way to do it so it all goes behind the motherboard tray. Anyone can do it as long as you take your time and think about each cables route. I have done a couple of mods on my case as its an antec 900 and not known for its cable managment prowess :) BUT if you choose your case wisely this sort of neatness can be achieved with no mods
Always useful to have a modular PSU
Although it's helpful, you don't need a modular psu to have a tidy case. I managed fine with my pc power and cooling. The only thing is at the back of the case where all the cables are, you get a bulge which you need to flatten. I get the same thing with my modular enermax though.
Wow thanks guys. They look fantastic!
Magicroundabout: Thanks for the back picture, that helps a lot. This should really help drop the temps a little as well.
If anyone else has some pictures of the back. Would be nice to compare techniques
you wanna see it in my thermaltake armor than :eek: even my graphics cards are odd as in totaly different althrough the same (onces ref the other is custom)
To be honest mate it depends on your case. I bought an Antec 900 a year or so ago and the cable managment in that is terrible. I've mangaed to hig a lot of stuff in the 5"1/4 bays but will never look as smart as the ones with the hidden back compartments.
Very similar setup here to Magicroundabout's... same Silverstone Fortress case, which has good cable mgmt features anyway, and a modular PSU which is just so useful in cleaning up things internally.
Front view
And the rear view...
I have since changed the SATA cables for black ones - I'll try to get some more pics soon:)
Just put all the wires behind the motherboard tray. It's not that hard if you put some work and thought into it.
I'll take some photo's later.
I thought there was some reason for not putting them behind the tray? Possible shorting or something.
Dont really fancy doing that as it took ages getting the CPU cooler on lol
I have a coolermaster stacker 856 (or something like that)
I did try to tidy mine, but some cables just weren't possible. Mainly the 24 pin power and PCI-E power cables, they weren't long enough to hide behind the tray.
The trick is having:
1. A good case, with plenty of options for cable routing (or mod yourself!)
2. Patience. Lots of it.
3. Modular PSU. Reduces the amount of cables drastically and makes the whole thing a LOT easier.
4. Right length cables. Make sure one cable goes where its neatest/best. Otherwise you'll be linking or changing to non-optimal layouts.
So, is there a method or order in hiding the cables around the back ?
I am getting an old Antec P180 in a few weeks which is known for not being the easiest case to be tidy in (my excuse, and a very good one too !) and plan to do a lot to it, but if there is a 'normal practise' in routing the cables it would be good to know !
I expect to do a dry run, then cut out holes for cables, then a paint job, then a final build, so am gathering all the info I can - D D Hanneh, extension cables are available if that would help you...
TBH Steve, when I did mine I found the key thing to keep in mind was what cables you might need to undo to swap out components - so if changing graphics card can you get to the power easily enough without having to undo everything else? You've gotta sort of think ahead to try to route things to minimise probs if and when swapping stuff out in the future - cause it's a real pain undoing all your good work to change things.
Others may have their preferences, but I'd prefer to put power in first, then data and fan cabling last as I'd poss be swapping out fans (or removing for cleaning etc) soonest - and being smallest they can be routed along other cabling to hide them away. Also when using a case like the Fortress, altho it has the rear cable mgmt tray you should try to avoid crossing the major power cables as the added bulk can affect how well the side panel fits!
Hi Si - thats the sort of answer I expect from you - wise words !!
As the main power cable are 20/24 cables or 8 cables, I intend to cut the braiding off mine to allow for flattening out of the bundled cables behind the mobo (No easy to cable manage case for me, you lightweight !!) and will work following your ideas. Having just got me a Noctua cooler I am getting ever more impatient to get my new case and fans out here to get started !
