TIFF or PNG
~D~
~D~
20 Jan 2007
PNG and TIFF formats both offer lossless compression when saving, thus preserving all the data in a picture and PNG file are a LOT smaller than TIFF files.
So my question is why is TIFF still the preferred method of saving photographs in a lossless format?
I save mine as Tiff with LZW compression, apparently pretty much lossless and only takes up about 10mb instead of 30.
TIFF lets me keep exif data.
I've tried saving as PNG with Photosohop and it strips all exif data.
I've always used ZIP compression. I'm gonna test out LZW and compare the two.
Zip takes much longer to save, is only slightly smaller, and can't be read by windows picture viewer. I would stick to lzw. i used the gimp, maybe you will get different results in photoshop.
I gave up on Tiffs long ago and I'd only use PNGs for web-graphics.
My work-flow consists of RAW and Jpeg with a Photoshop file in between should the need arise.
Panzer
lightroom dosent read png and photomatix can output in tiffs so raw > dng on import and jpegs for posting and tiff > dng when creating hdr and importing and png for photoshopping
