Permabanned
- 19 Jun 2007
- InURmama
DDR3 1333MHz Memory at 4-4-4-12 Timings?
" The days of saying DDR3 memory can't run tight timings are long gone now that memory kits can run 1333MHz with 4-4-4-12 timings with a little extra voltage. It just goes to show that it is possible to run tight CL4 or CL5 timings on DDR3 and it is likely that upcoming memory IC's might be able to improve on the frequencies at which these tight timings can be run. The Corsair WIN3X2048-1800C7DFIN G DDR3 memory kit is the only DDR3 kit that I have seen run CL4 memory timings above 1333Mhz..."
http://legitreviews.com/article/601/1/
The only part I dont agree with is you do not need Memory at 2000mhz to be In Sync with a Intel at 500FSB as they are Quad Pumped so CPU is 500x4= 2000FSB and Memory only needs be 500x2 =1000mhz.
