Tight Fit?
14 Sep 2009
Northumberland
Hi, I want to ut a Titan Fenrir in the NZXT beta case, and want to fill the two 120mm fan holes at the side with two fans. They are standard thickness fans.
The case is 200MM and the Fenrir is 156MM. The fans are Noiseblocker BlackSilent Fan XL1
Will it all fit?
