- 30 Jul 2007
After a lot of ups and downs and false starts, I now have my rig stable.
The only aspect i havent tweaked so far is the memory. I would like to tweak the memory for maximum performance but need advice please.
q6600 G0 3.6 Ghz (400x9) @ 1.32v, 31 idle, 61 load
TRU 120 with Noctua 1200 RPM
asus maximus formula
Corsair Dominator 8500 Ram
Antec P182
Current Memory Bios Setting (strap 400, Memory 800Mhz, 5,5,5,18, 2,2 Volts ie basically on auto)
should I be looking to get the tightest timings at 800Mhz, or the most amount of Mhz out of the memory.
Advice on the sorts of volts / timings i should be aiming for (both primary and secondary). From a previous post yellowbeard has advised that I should get 4.4.4.12 @ 2.2v or better but i dont know at what secondary timings i should go for or just leave on auto.
At this stage i do not envisage raising the FSB any more for day to day usage and am looking for the best system performance at 400fsb.
The performance is just needed for games (but also for curiosity / epeen)..in reality does memory performance make much odds to min frame rate in games..im suspecting not.
Im using Prime Blend for stability test, everest for synthentic benchmark and crysis benchmark for real world benchmark...any better suggestions? Are there certain types of games which are sensitive to memory performance/bandwidth.
Antec P182
