Digital Punk said:Of the ones I've used I found Ultra VNC the best.
I use it on my lan and it has the ability to transfer files as well which is very useful.
Clarkey said:VNC security is very weak anyway, 8 character password max with only 56bit DES, easily brute-able, and the actual video data is unencrypted. TightVNC themselves recommend you don't use it over the internet.
In which case, choose any - just don't make any pin holes in your firewall and it wont be accessible from the internetCraig321 said:Only being used over the LAN at the moment, it's probably inaccessible over the internet, but I'd rather be safe though![]()
