Time for a BFGaming (and other stuff) rig
3 Mar 2014
Afternoon all,
I've had my current build for around 7 years, an i7 4770k, 32GB RAM, RTX2060 etc., which I'm going to keep and shoehorn into a smaller case that its current CM Storm Trooper (be quiet PB 500).
I'll mostly be using the new rig for P3D v5, with a whole bunch of addon sceneries, weather engines, and study level aircraft, and ideally I want to get smooth frame rates while on ultra settings at 1440p on a 34" widescreen. I also want it to be able to last at least 5 years without needing to upgrade, so running MSFS at higher settings in the future once MSFS is up to a good standard. I'll also be using it for running various numbers of VMs, too.
My budget is ~£5k
So, the build, is:
My basket at Overclockers UK:
  • 1 x OcUK Tech Labs AMD Ryzen 3rd Gen Pro Gaming Configurator = £4,712.69
    • CPU:AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor - Retail
    • Motherboard:Asus ROG Strix X570-F Gaming (AMD AM4) DDR4 X570 Chipset ATX Motherboard
    • CPU Cooler:ASUS ROG Ryujin Performance AIO CPU Liquid Cooler with OLED Display - 240mm
    • Memory:Kingston HyperX Fury RGB 32GB (2x16GB) DDR4 PC4-28800C18 3600MHz Dual Channel Kit
    • M.2 Solid State Drive 1 (Primary Drive If Selected):WD Black 1TB SN850 SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS100T1X0E)
    • M.2 Solid State Drive 2:WD Black 2TB SN850 SSD M.2 2280 NVME PCI-E Gen4 Solid State Drive (WDS200T1X0E)
    • 2.5" SATA Solid State Drive 1:Unwanted
    • 2.5" SATA Solid State Drive 2:Unwanted
    • Mechanical Hard Drive 1:Seagate BarraCuda 2TB 7200RPM 256MB Cache Hard Drive - *System Stock*
    • Mechanical Hard Drive 2:Unwanted
    • Power Supply:ASUS ROG THOR 1200W 80 Plus Platinum Modular Power Supply
    • Soundcard:Unwanted
    • Network Adapter:Unwanted
    • Case Lighting:phanteks Digital RGB LED Starter Kit
    • Operating System:Unwanted
    • Security Software:Unwanted
    • Build Time:Standard Build Systems - Dispatched in approx 10-15 working days
    • Headset:Unwanted
    • Keyboard:Unwanted
    • Mouse:Unwanted
    • Monitors:Unwanted
    • Speakers:Unwanted
    • Gaming Chair:Unwanted
    • Gaming Desk:Unwanted
    • Cases:phanteks Eclipse P600S Glass Silent Midi Tower Case - Gunmetal Grey
    • Graphics Card:*Build Stock* Asus GeForce RTX 3090 ROG Strix Gaming OC 24GB GDDR6X PCI-Express Graphics Card
Total: £4,726.79 (includes shipping: £14.10)
Although I'm trying to find out if I can swap the 5800X for a 5900X at the moment.
It should still be within budget, just, with a 5900X, and should have no issues running current games at ultra with a decent frame rate, I'm just wondering if there's anything I've missed or anything that I should consider before I push the button?
saving some cash . White build can house 3090 if you really want to pay that much for a very inflated GPU chip
  • 1 x OcUK Gaming Empath - AMD Ryzen 7 5800X Gaming PC = £2,299.02
    • Case Colour:*Build Stock* Lian Li O11 DYNAMIC MINI MIDI-TOWER CASE - BLACK
    • Graphics Card:*Build Stock* Gigabyte GeForce RTX 3070 Gaming OC 8GB GDDR6 Graphics Card
    • Primary M.2 Solid State Drive:Seagate Firecuda 520 1TB SSD PCIe Gen4 NVMe M.2 Solid State Drive (ZP1000GM3A002)
    • Secondary Solid State Drive:Unwanted
    • Operating System:Microsoft Windows 10 Home Advanced - Systems
    • Security Software:**Special Offer** Bullguard Internet Security - Anti-Virus and Security - 1 Year 3 PC
    • Processor:*Build Stock* AMD Ryzen 7 5800X Eight Core 4.7GHz (Socket AM4) Processor - Tray
  • 1 x OcUK Gaming Glacier - Gigabyte Vision, RTX 3000 Series Gaming PC = £3,117.04
    • Graphics Card:*Build Stock* GIGABYTE GEFORCE RTX 3080 VISION OC 10GB GDDR6X GRAPHICS CARD
    • Memory:Kingston HyperX Fury 32GB (2x16GB) DDR4 PC4-25600C16 3200MHz Dual Channel Kit (HX432C16FB4K2/32)
    • Primary Solid State Drive (M.2):WD Black 1TB SN750 M.2 2280 NVME PCI-E Gen3 Solid State Drive (WDS100T3X0C)
    • Secondary Solid State Drive (M.2):Unwanted
    • Primary 2.5" Solid State Drive:TeamGroup 1TB Vulcan G SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • Secondary 2.5" Solid State Drive :Unwanted
Total: £5,439.16 (includes shipping: £23.10)
if vrms, then pump up to 5900x! OCUK should be able to do that fine! Just 5k on a system that will be outdated CPU wise Q4 is hurt! 3080Ti rumored in May to! 3090 without the extra ram and ££​
Why outdated cpu wise the 5800s 5900s not be high end by Q4? :o id recommend not paying the over the top price on the GPU, as @orbitalwalsh mentions the 3080ti is rumoured to be coming soon im holding and hoping for one of those!
you have intel's 12 gen rolling out . can see performance wise the design is doing well in laptop range.
should be seeing leap frogging soon between AMD and Intel. AM5 should be end of Q3/start Q4 but could roll out Zen3+ refresh . interesting times.
If you've got the cash, £5k then you can easily buy ! Just have to stomach you know your paying more for then GPU and Ryzen 5*** series .
3080ti will be like hotcakes if miners can't use it, but everyone that's been trying to get a 3080 or even 3090ti at close to launch price will jump on them . 12GB would help your flight Sim, or 6900 16GB !
