- 18 Jan 2011
- A remote car park
It really is time to upgrade but I am well out of the loop with PC building, so looking for some advice..
Current antiquated rig -
Phenom x6 1090t
8gb corsair DDR3 1600
Gigabyte GA-MA78LMT-US2H AM3 (Micro ATX)
100GB Corsair SSD and a couple of mechanical HDD's for storage
GTX650 (I don't do gaming)
BE Quiet 550w PSU
Zalman case
Freeview HD Dual Tuner (using a low profile TBS 6820 PCI-E card) which will be going in the new rig.
Only used as a HVR, TV, media centre, VirtualDJ 8, web browsing, a bit of video production (Adobe AE, PP) and a fair bit of video encoding (both HD & SD)
Only real requirements are a PCI-E x1 slot (for the HD TV Tuner card) no need for high end graphics, (onboard DX11 should be sufficient)
onboard sound is sufficient for my needs.
Windows 7 will be used.
8GB ram will be enough, I barely go over 6GB even in AE.
Could probably do with a bigger case as the zalman is tight even with a micro-atx board so might as well get one.
I wont be overclocking, so aftermarket cooler will not be required.
So, for about £600 any suggestions of the best bang per buck?
CPU, MB, RAM, PSU, CASE
I will add some extra HDD's myself and any other peripherals (new mouse, keyboard etc) and they are not in the £600 budget.
Thanks in advance for any suggestions
Phenom x6 1090t
BE Quiet 550w PSU
Zalman case
