- 18 Oct 2002
- Newton-le-Willows
It's been a while since i posted on here but I need some advice. I've been away from the whole hardware scene for a few years and I need to upgrade my PC but don't know what goes with what and what is best value and suited to the particular things I use my PC for.
I use my PC for general office and web based tasks but I have recently become addicted to FSX in a big way and my current kit just doesn't cut the mustard any more. I know it's very CPU dependant so that is the key in this upgrade.
I currently have the following kit: -
Intel Core 2 Duo E6300 (1.86Ghz @ 3Ghz)
Gigabyte P965 DS3 Rev 1
Corsair 4x1GB DDR2 PC6400
WD Raptor 74G (OS)
Seagate Barachuda 250GB (Media etc)
Maxtor 120GB (so old i don't know the model - Apps)
Leadtek Nvidia 8800GT
SB Audigy LS
Lan-Li PC-8A case
Enermax 750W PSU
22" Samsung Suncmaster 226BW (runs FSX at 1680 x 1050)
This is running a 32bit version of Vista Premium but will be upgraded to 64bit vista/Windows 7 soon.
Looking at the Gigabtye Website my mobo can't take any of the Core 2 Quad CPUs so i think i need to rip out the core bits (CPU, Mobo, RAM)
I'm not bothered whether it's Intel or AMD as long as it will run FSX pretty well.
I have a budget of around £300 so not massive but enough to get some decent kit. If possible i would like a dedicated HD for FSX as i have quite a few add-ons and i am planning more which will take up a fair bit of space, something around 300GB would be fine.
Thanks in advance for your suggestions.
WD Raptor 74G (OS)
SB Audigy LS
Lan-Li PC-8A case
Enermax 750W PSU
