I'm having a couple of stability issues with my current rig, which has been going for a while on the strength of 'well, it's just about ok for what I'm doing with it, and if I wait a little longer then x will be out and it'll be a better buy'. But obviously if you keep it like that then you just never end up upgrading. So I'm looking at finally pushing the boat out. My current rig:
Phenom II x6 1055T @ 3.5Ghz
Gigabyte 890GPA-UD3H mobo
OcUK H2Flo cpu cooler
2x4Gb DDR3 ram (Gskill ripjaw 10666 C9)
AMD 6870X2 2Gb graphics
OCZ StealthXStream 2 700W PSU
Usage wise, it's lots of gaming, recording, encoding video and ideally some live streaming as well.
Ideally I would stick with an AMD rig, but honestly while I have some principles, they are easily bought, so if there's a better option for the same price then I don't mind grabbing an Intel or Nvidia part.
Getting something fairly future proof, or at the very least powerful enough to last a good few years is important, this 1055T has lasted me just over 4 years now, so I've certainly gotten my worth out of it.
Finally, budget wise I would be looking at around £600 tops, but can spend a little more if it's going to be a significant upgrade for a little more cash. I'll be keeping all my monitors, peripherals and so on, there's no PCI cards or anything like that to worry about.
Thanks!
Thanks!
