Hi All,
Got that feeling again... Time for an upgrade. I'm ok for drives/ssd/case etc. Thinking of going for a new CPU/MEMORY/MOBO/COOLER and installing in my existing case.
Current spec.
PC is switched on 24x7 so needs to be quiet.
I'm not a gamer but use the PC mainly for photo/video work. Plex server. I want to go for a i7/16Gb level spec. Got around £600-700 to spend on this. Got a full size case so don't need micro ATX.
I hope to retain;
Case Antec
Corsair 520w power supply.
128Gb SSD and drive
1 x 2Tb WD black
1 x 3TB WD green.
Graphics is a GV-NX73G256D-RH ( told you I wasn't a gamer ! )
1 x burner (bluray)
Win 7 64.
I run 2 x 24 inch monitors (Dell ultrasharp ) so I could also add a reasonable graphics card ( quiet ) would be great but don't need anything amazing. This can be in addition to £600.00.
Thanks to all in advance.
Wert
Current spec.
- 2 x Corsair XMS3 4Gb ( 2 x 2Gb ) DDR3 PC3-12800C9 1600Mhz Dual Channel Kit (CMX4GX3M2A1600C9 ) so 8Gb in total ( 4 x 2Gb )
- Intel Core i3 530 @ 2.93Ghz Clarkdale ( socket LGA1156 ) - overclocked.
- Gigabyte GA-H55M-UD2H intel H55 ( SOcket 1156 ) Motherboard v 1.3 - micro ATX
- Arctic cooling freezer 7 pro.
I hope to retain;
Case Antec
128Gb SSD and drive
1 x 2Tb WD black
1 x 3TB WD green.
1 x burner (bluray)
Win 7 64.
Wert
