Time for an upgrade.
24 Nov 2002
Abertawe, Cymru.
What's a good budget ryzen build to replace the computer in my signature. Keep in mind I'll be keeping everything apart from the motherboard, cpu and ram.
My trusty FX8200 has served me well but I think it's time for an upgrade.
Any suggestions, been out of the loop for ages xD
Cheers.
SJ.
Budget is about £350 but cheaper the better.
I'm guessing you'll be gaming on this machine... The below spec is a tad over budget but will be a great path to upgrade... Also its an ATX motherboard so I'm hoping you have a ATX case :p
My basket at Overclockers UK:
Total: £369.47 (includes shipping: £10.50)
Thanks, yeah I have a large atx case. At the moment it has a matx motherboard but want a full size one.
Thanks for the suggestion.
