Time for another Crysis Mod
27 Apr 2014
Two versions to pick from and comes with installers to install Time Of Day Files and textures.
Updated missing textures
Download Mod-Crysis 2020 Extreme Particles and Dynamic Fire for high end PC
https://drive.google.com/file/d/1ZKymdcY3Ibh8UJ8xSWZMZxFD17Vquzua/view?usp=sharing
https://drive.google.com/file/d/1QGWjlR7fR92i-P4PBktpLS153rUs2wRL/view?usp=sharing
Always back up your own files and autoexec.cfg has bind commands.You can change to whatever you want.
Mod has files to fix 24Hz bug and fixes for CPU's to stop crashing,not working in Windows 10.
I suggest play with wclaws and no guns for awesome fun.
Wclaws
In console type- i_giveitem wclaws
IncendiaryAmmo
In console type- i_giveitem FY71IncendiaryAmmo
Wclaws
How to install.
1.Best results is to play in devmode.Also for Mods to work Correctly.Start new level to avoid errors.Example no tires on LTV.
ADD(-devmode)to crysis target line in shortcut to game.Or add to launch command for game.Will work on steam/origin versions
Looks like:Electronic Arts\Bin32\Crysis.exe" -devmode
2.Always Delete Shader Cache files before adding new Shader files to avoid errors.
(C:\Users\yourname\Documents\my games\Crysis\Shaders\Cache)
3.Unzip/extract all files to game folder.Overwrite all files,original back ups are supplied for origin patched game.
Origin Games\Crysis\Game
4.Click on the Installer of your choice for Time Of Day Files(5 different ones to choose from)
Uninstall Time Of Day files clcik on Installer CrysisTOD.bat- (This will install Crysis default Time Of Day Files)
5.How to uninstall-Use your own back up you made or the one provided
Folder Back Up Original Files copy and patse the Crysis Folder into your install game folder
Origin Games\Crysis
Delete these files from
ZPatch2.pak
zz_Nanosuit_v2_Gear_With_Attachments.pak
zz_wclaws.pak
6.To delete indivual mods,use links provided and use 7zip or similar to open there .pak files and delete the excat content you want to delete from Zpatch1 folder.
Thank to the original modders of the Time Of Day Files
1.BlackFire's Mod Ultimate 1.3
2.Crysis CCC 2.21 mod
3.Crysis ToD Mster Config 3.01v
4.Crysis RELI2
5.Natural Mod
Other Mods,some added testure POM files not listed.
https://www.playground.ru/files/crysis_nanosuit_v2_gear_with_attachments-114262/
Crysis - AMD's 3D Now! fix 1.0.0
https://www.playground.ru/files/crysis_fiks_dlya_amd-193990/
Crysis (64bit) - Unhandlead point inexact result exception fix 1.0.0
https://www.playground.ru/files/crysis_fiks_dlya_64_bit-193988/
Crysis 60 FPS fix
https://www.playground.ru/files/crysis_60_fps_fix-190906/
Crysis HD Textures 2018
https://www.moddb.com/games/crysis/downloads/crysis-hd-textures-2018
Vietcry
https://www.moddb.com/mods/vietcry/downloads/vietcry-non-setup-version
newshaders
https://www.playground.ru/files/crysis_new_shaders-158333/
zz_newCrysisrocks
http://www.mediafire.com/file/hceb7tah3qe97bl/zz_newCrysisrocks.pak/file
zz_treepalmtexture
http://www.mediafire.com/file/xgdegw5b4pfz4be/zz_treepalmtexture.pak/file
crysis_texture_update_pack
https://www.fileplanet.com/archive/p-44893/Crysis-Rygel-High-Texture-Mod/download
zzz_HDGrass
http://www.mediafire.com/file/s1j93zz5qihip3b/zzz_HDGrass.pak/file
zz_XtremeFX
http://www.mediafire.com/file/m3r1f4p7ed18v6r/zz_XtremeFX.pak/file
zz_PureBlood
http://www.mediafire.com/file/llt7jaolcp5h760/zz_PureBlood.pak/file
zz_weapons_scripts
https://www.playground.ru/files/crysis_crysis_warhead_weapons_mod-165377/
zz_CNW_HUD
https://www.playground.ru/files/crysis_novyj_hud-95545/
Dynamic Fire Alpha
https://www.playground.ru/files/crysis_dynamic_fire_alpha_1_2-21896/
thanks a give these a go hearing that they are making a remake of crisis..
Yeah that is why I tossed together the mods again.
Do you need the original game? Never could get it working on windows 10.....(got it on Origin)
I added fixes for Windows 10 and works fine and no crashing on Windows 10 anymore.
I used Origin version of the game.
Do either make the second half of the game not crap? :D
Oh your forgot Tech Demo and .... :D
Ah sorry, I read that as "its not working in windows 10". Will try it. :D
First Crysis is my favourite of the series, probably the only shooter I played through more than once.
I loved messing with the Crysis game.Also the only shooter I played more than once.
When I click start new game I get the video (which I skip, obviously) and it just goes to a black screen. Which is further than I got previously. Still no good for windows 10, for me. :(
I guess all I can say is.I have the Origin version installed and the retail version installed and they work on windows 10 .Sorry do not know what else to say other than alt+tab or alt+enter to force windows mode then back to full screen to get rid of the black screen.
OH I am an idiot,you can always try Crysis compatibility mode vista service pack 2
crysis
