31 Oct 2010 at 21:21 #1 wakayoda wakayoda Associate Joined 9 Mar 2009 Posts 1,102 How does this look? Any advice/recommendations? Currently using an AMD X2 with 3gb of RAM
31 Oct 2010 at 21:24 #2 RJC RJC Don Joined 29 May 2005 Posts 29,103 Location Kent Change the ram to dual channel like the ones below: http://www.overclockers.co.uk/showproduct.php?prodid=MY-203-CS&groupid=701&catid=8&subcat=1517
1 Nov 2010 at 09:45 #3 wakayoda wakayoda Associate OP Joined 9 Mar 2009 Posts 1,102 So is it better to have 4Gb of duel channel then 6Gb of single channel? Also whats better an i5 or a 6 core AMD processor?
1 Nov 2010 at 10:06 #4 hp7909 hp7909 Soldato Joined 8 Jun 2003 Posts 4,959 Location NBO wakayoda said: So is it better to have 4Gb of duel channel then 6Gb of single channel? Also whats better an i5 or a 6 core AMD processor? Click to expand... Intel Core i3, i5 & the AMD line-up support Dual-Channel memory which would be faster than Single (not to mention cheaper). Compare the CPUs here
1 Nov 2010 at 14:45 #5 95thrifles 95thrifles Permabanned Joined 15 Nov 2008 Posts 6,968 If youre prepared to spend that, you may as well get the bundle, here, with aftermarket cooler and preOCd for you
