Time Machine configuration..
5 Nov 2004
Is it possible to set Time Machine up so it doesn't use your entire drive for backup? Right now I have a USB 2TB drive and its going to keep eating it up until its full at that point it will discard old backups. Can I not specify I only want say a months backup storing?
Only option is to partition it. Having said that it works pretty well, make it a reasonable amount bigger than your machine's drive and you should in theory have at least a complete backup all the time.
You don't need to partition the drive, just do a bit of fiddling with the timemachine "sparsebundle" to configure a maximum size. Do a search for getting time machine to work on a NAS and you'll find what you need.
