10 Nov 2010 at 13:37 #1 ajf ajf Soldato Joined 30 Oct 2006 Posts 3,067 Location Worcestershire, UK Can you use just part of a USB disk for Time Machine? For example with a 1Tb disk can I allocate 400Gb for Time Machine use? New to Mac so not sure and want to check before I try and connect the disk! Thanks Andrew
10 Nov 2010 at 13:38 #2 QwaF QwaF Associate Joined 20 Sep 2009 Posts 566 Yeah, just partition off 400GB of the disk in Disk utility.
10 Nov 2010 at 22:55 #3 Skyboat Skyboat Soldato Joined 13 Jan 2005 Posts 3,374 Location South West QwaF said: Yeah, just partition off 400GB of the disk in Disk utility. Click to expand... Yeah what he said, Disk Utility makes it so easy.
10 Nov 2010 at 23:12 #4 ajf ajf Soldato OP Joined 30 Oct 2006 Posts 3,067 Location Worcestershire, UK Cheers. All sorted.
