Time Machine Over Network
  • Thread starter Thread starter Deleted member 329
  • Start date Start date
Deleted member 329
Deleted member 329
Hello,
I am looking for a cheaper way to use time machine over wireless network.
Here is the setup - 1 Macbook hooked up to non apple wireless rounter
1 XP SP2 PC with 2TB+ Storage/Workhorse mahine
Now i heard there was way to get time machine to backup to an unsupported network volume, I used a terminal hack to enable unsupported drives, unsupported drives now show up but i have no joy backing up to the over wireless or wired.
now i really dont think i need a time capsule. really i should be able to do it with the technology i already have at hand.
Does anyone here have experience with using Time Machine over a network to and XP machine?
If so and you have used the unsupported drives hack, how would you restore that backup in the event of a hard drive faluire? Wouldn't time machine not read from the unsupported drive when it came to restore?
any help would be appreciated, dont facey being suckered into buying somthing i dont really need :)
did you have any luck with getting TM to backup over the network to a windows share? Ive found the hack so i can see the drive, but it always fails!
Not tried it yet.. combination of making space, getting time when I can plug the MBP into copper and having the array switched on..
I the FS under my samba is linux JFS. What does Samba have in it's log?
where can i find the Samba log? I got a MBP yesterday, so im VERY new to this... not even 100% sure what Samba is!?
Samba is the program that acts as a windows file server. It is usually on a separate machine rather than the MBP.
I have a SuSE linux box which runs Samba. My MBP can then connect in easily, as can my windows games box.
It will be under /var/log/samba as log.* (ie log.smdb) on the box running samba.
