- 16 Aug 2005
- Cardiff
Just wondering how many people use this?
I'm asking because I think it's a really good feature, but the ability to only use it with USB HDD's plugged into the machine itself is annoying (I like keeping my iMac a wire free zone
If you do use it, have you used the command to enable the use of a network location? If so how stable is it?
Thanks!
)If you do use it, have you used the command to enable the use of a network location? If so how stable is it?
Thanks!
