Timer socket with override?
31 Jan 2022
UK
Does anyone know where I can find an electronic 24hr timer socket with a manual override? I have some mechanical timers and some electronic ones but although the electronic ones are more flexible, they don't have a manual override. Or at least not one that is nice and easy to operate when you are reaching down the back of a cabinet!
Smart switch for sure. I use TP Link Kasa stuff (HC100 iirc) and it has timer and manual on/off. Currently using it on my immersion heater (lols).
I'd get a mechanical smart wall switch put in a wall box and wire it inline - can be a dimmer too eg https://sonoff.tech/product/smart-wall-swtich/m5/
I've wired dimmers into existing standard lights in this manner.
(led bulb compatability with dimmers is still an issue though)
not sure I'd use a smart switch for a 3KW immersion heater long term (3Kw anything ! my pressure washer too say a big reactive load lol),
mechanical relay with heavy currents, what could go wrong.
Another vote for TP-Link Kasa stuff. Got both types of plugs, extension leads and bulbs. Can override from App or Alexa and the like. Also really like the sunset / sunrise option so it auto adjusts as the evenings draw in / go out.
Not much more expensive than mechanical ones either as often on offer.
TP Link Kasa - you can also get ones with energy monitoring built in (I use these and link to home assistant for all the control/stats etc!)
Deffo use smart sockets...
I had a raft of TP Link / Samsung and Amazon smart sockets.
I would say that heavily used (10 times per day), I've had 3 TP Link HS100's effectively stop working after around 3 years of heavy use, they are working in so far as they appear in the app, and you can hear the internal relay click when it tries to power on/off but there is no mains coming out the socket.. This is after 3+ years of use.
I've not abused the other brands enough yet to figure out if they also suffer, but 3 years heavy use for £30 isn't that bad, the others TP LInk sockets are still in use today (5+ years old now) and working a treat.
