Hi I'm currently doing a timing belt fitting but finding it impossible to get the new cable over all the pulleys/sprockets. Its as if the belt is too short.
I have double/triple checked the belt numbers and that it is the correct one they only do one for my car.
How tight does the belt need to be? , the only way I will get the belt on is with a screw driver and allot of force,but i don't want to damge the belt.
Car is a peugeot 406 2.1td 1998
