Timing belt question - Volvo V40
2 Jan 2016
Yorkshire
Hello all.
Just wondering if anybody knows if and when this should be done? I can't see anything in the manual and can't find anything definitive online.
It is a 62 plate if that helps.
Cheers
maybe ring Volvo and ask them, I don't know about Volvos but they may use timing chains now instead of belts
Belts on these.
I believe you're looking at 6 years/108,000 miles but would definitely be worth confirming.
10 years!! That seems awfully long. I know belts wear with use, but they'd also deteriorate over time.
Just sorting out the timing belt for my partners Seat Ibiza, and that's 4 years/80k.
I agree. Mine on the porsche is 6 years or 60k.
Ford tends to have a long recommendation too. My partner has just hit the 80k mark in her 2012 Focus so I decided to look into her belt replacement, turns out its 10 years or around 100k! For reference my car had a 4 year schedule. I believe seat have increased that to 5 now last time I checked on the service website.
