- 25 Nov 2009
can anybody put in simple terms what these are all about? ive read the sticky on ram an its still unclear. im maybe looking at tweaking my ram.
cheers
cheers
cheers![]()
cutted and pasted of various wiki pages said:tCAS The number of clock cycles needed to access a certain column of data in SDRAM. CAS latency, or simply CAS, is known as column address strobe latency, sometimes referred to as tCL.
tRCD (RAS to CAS Delay) The number of clock cycles needed between a row address strobe (RAS) and a CAS. It is the time required between the computer defining the row and column of the given memory block and the actual read or write to that location. tRCD stands for row address to column address delay.
tRP (RAS Precharge) The number of clock cycles needed to terminate access to an open row of memory, and open access to the next row. Stands for Row precharge time.
tRAS (Row Active Time) The minimum number of clock cycles needed to access a certain row of data in RAM between the data request and the precharge command. It's known as active to precharge delay. According to Mushkin, in practice for DDR SDRAM, this should be set to at least tRCD + tCAS + 2 to allow enough time for data to be streamed out.
RAM speeds are given by the four numbers above, in the format "tCAS-tRCD-tRP-tRAS".
So, for example, latency values given as 2.5-3-3-8 would indicate tCAS=2.5, tRCD=3, tRP=3, tRAS=8
hm right ok then thanks, so where would i start then when overclocking?
say for example it is 7-7-7-20 would i lower all of the 7's to 6's or just one at a time or something?
think im gonna leave it for a while until i actually understand how it all works... not like its slow a it is.
cheers![]()
