Hello all,
I've currently got 2x1Gb sticks of Corsair XMS2, and am trying to upgrade to 2x2Gb sticks of Corsair XMS2 Pro, so leaving my other 2 slots free as I am considering the pros and cons of a 64bit system with 8Gb (the most my motherboard can support). So here are my questions:
Both sets of sticks are 800Mhz, the fastest my board will support, and from what I can tell are the same in every respect except that the "old" sticks have 4-4-4-12 timings and the new have 5-5-5-18. Will this be a problem? And do I have to do anything special with the BIOS to account for this.
Also, the PC is one of the overclockers.co.uk OC systems, and from what I remember the memory was supposed to have been overclocked. Is this likely to cause any problems when I plug my new sticks in? A friend recommended that I first take a look in the BIOS and maybe turn off any overclock settings before installing the sticks.
Finally, is there anything I need to know about the process of installing the memory, from what I could gather online most of the process is automated by the PC and aside from the possible issues above I should just be able to swap them over with no problems.
While I'm posting in the memory forums; if I might upgrade to Vista 64-bit at some stage in the future, will the additional 4Gb of memory need to be another of the same type of sticks? Just trying to decide whether to pick up a second set now in case I can't get the same again down the line.
