Tiniest hub/switch please
12 Mar 2003
USA
Hey,
Looking for a tiny hub/switch which I can squeeze into my AV stack and hook up my PS3 and Wii to as the wireless reception in the lounge isn a bit pap!
Any recommendations? GigaE not an absolute necessity, but preferred. Reasonable sized AC adapter would also be lovely!
Cheers,
Suman
2 at the moment, but it'd be great to have 4 as I plan to add a NAS box soon (the Thecus YES box which has teamed dual GigaE connections).
Cheers,
Suman
Netgear GS108
8 ports, small and lifetime warranty. Jumbo frame support too. Not too badly priced.
Could always get the whitebox cheaper GS608 too, which also supports jumbo frames.
Both only about as wide as 8 ports.
Depends on the size of the rack though. What's the max size?
Try a netgear ProSafe GS105 - it's a 5 port, gigabit switch.
9.5cm w, 10 cm deep, 2.5 cm tall
Around 40 from online stores and it is a heck of a lot smaller than the one posted. It is the dark blue metal colour
