My OC has worked out fine but wondering about pushing it a bit further and looking for some advice.
It's an E2160 on a P35-DS3L with 800mhz ram.
I've set it up as 9x333, core voltage 1.29375V, RAM voltage at 2.1V (as rated by the manufacturer) and the SPD is set so that the RAM speed shows up equal to the rated speed 800 this is a multiplier of 2.4 (not entirely sure what this means to be honest). I manually set the RAM timings to the ratings from the mrfr (4-4-4-15) and set the MCH read delay (tRD) to 7 (was 11). Idle core temps 32C, northbridge the same. 100% load temps are 60C. All tested with a Blend test on Orthos and is stable.
I'm on stock Intel cooling. Temps were hotter but my new case has helped a lot.
My Q's are:
1. Should I push this anymore with a stock cooler?
2. If I up the FSB speed then the RAM speed shows up higher than 800 - should I accept this or lower the multiplier, which at all but a few speeds won't match 800 but will be lower. How important is this?
3. What would the effects of lowering the step to 8 whilst upping the FSB a lot more be?
4. If it needed to loosen the RAM timings to say 5-5-5-x - is that going to make much difference to the performance?
5. How much heat can the northbridge take?
Many thanks
My Q's are:
Many thanks
