Tiny cheap mATX case recommendations
27 Jul 2009
Hi there,
I am hoping to re-use an old mATX motherboard as a mediaportal client in my bedroom, so I need to replace the massive case that it is currently in with something much much smaller. My only requirements are a single 3.5" drive slot and room for a regular PSU.
I will be using integrated graphics as well.
Can you guys recommend something ultra small that would fit the bill?
Thanks
