I need to remove some paint from some decking and and part of the fence. The fence should be straight forward just some paint stripper then sand it off but the decking may be trickier as sanding won't get in between the grooves unless I spend hours hand sanding in between. So any tips for sorting the decking out?
Also what paint stripper do you guys recommend? And what am I best to use to coat the fence and decking once cleaned down? Some ronseal in whatever finish the other half likes?
