Tips to improve my simple member login.
11 Oct 2008
Hey guys,
I currently have a very simple members area, I was wondering if anyone could give me any tips on how to improve it. It basically works like this.
if session exist
echo <<<adminarea
admin control panel here
adminarea;
else
echo <<<loginpage
etc etc.
That works fine for what I need but If I ever want to expand it, I'm rather limited by the fact everythings contained in the one heredoc.
I have tried re-directing the page if the session doesn't exists but it still flashes a glimpse of the content page before it does.
Any tips on how I should be securing the admin page ?
Thanks for any help
I tend to separate bespoke admin areas, so /admin that way i can also then lock it further if required like ip lockdown.
If it is showing a glimpse of content it shouldn't it is possible that your session checks are in a odd order which is causing some if statements checking a value prior to its reset.
I think its just the re-direct being too slow.
I was using
PHP:
<?php
    if (!isset($_SESSION['username'])) {
echo <<<FORM
<script>
    function reloadPage() {
    window.location.assign("?nav=login")
</script>
<body onload="reloadPage()">
FORM;
Ah your relying on javascript todo the redirect.
Instead of that use a php function to do a instant redirect, header('Location: /?nav=login');
