Tired of blowing :)
Funnily enough I just bought the white one for £35 as I am about to redo the location for all my equipment and thought I would give them all a good blowjob before putting them in their new place.
I've got a squeezy air ball thing + a nice brush that I use to clean out dust from a PC. The brush disturbs the dust and the air ball spreads it around my room clears the dust.
I've got a £10 mains powered airbed pump that does a great job.
Mainly used before I have to get intimate with the internals of someone else's PC. Stick something into all of the fans to stop them spinning and then give it a good blast.
Used this today and it does a nice job even on normal speed its powerful enough .. my pc does have fan filters and my pc is not near the carpet its surprising how much dust gets into the radiator vents in a short time.
Its not expensive really when you consider how much you can spend on those cans of air which last 2 mins:p
