Go to Page 12 in Manual
Access the router and go the Quick Set up display
Un tick the box “DSL Auto Connect” if tick
VPI leave as 0
VCI change to 38
Tick “Enable Quality Of Service” Next
Tick PPPoE
“Encapsulation Mode” change to “VCMUX” Next
Enter “Username” “Password” and select
“Authentication Method” (AUTO)
Tick “Dial on demand”
Inactivity Timeout set to 0
“PPP IP extension” leave un tick Next
Tick “Enable Wan Service” Only Next
Tick “Enable DHCP Service” Only
Un Tick “Configure the second IP Address” Next
Tick “Enable Wireless”
Enter a SSID Name: - This can be any thing that you want to call your wireless system example “43grassmonkey01” Next
You will get a Summary of the setting
Save & Reboot
