Tital Virtual Force VR - Questions
24 Mar 2016
So following a steer from the VR forum I have settled on what I want the VR PC to be, it's the Tital Virtual Force.
I don't just want to use it for this - it has to replace my seven year old desktop ( that sadly did run Rift DK1 and DK2 fine! ).
It also needs some additional components which I'll order at the same time and call them and ask them to build within it.
Can anyone see any problems with the below and perhaps anything that I might have overlooked ?
My biggest worry is change of case will it fit my needs for now and the future. Not physically seen one in real life - I worry too much!
Thanks.
Tital Virtual Force VR Gaming PC
https://www.overclockers.co.uk/tita...-nvidia-geforce-gtx-980ti-6gb5-fs-002-og.html
- Case - Cougar MX310 Midi-Tower Gaming Case - Black Side Window
- Need expansion - want a BluRay burner
- Intel Core i7-6700K 4.0GHz (Skylake) Socket LGA1151 Processor - OEM
- Kingston Fury Black 16GB (2x8GB) DDR4 PC4-19200C15 2400MHz Dual Channel Kit - Black (HX424C15FB2K2/1
- OcUK GeForce GTX 980Ti "Super OC Reference Design" 6144MB GDDR5 PCI-Express Graphics Card
- Samsung SM951 256GB M.2 PCI-e 3.0 x 4 NVMe Solid State Drive (MZVPV256HDGL-00000)
- Seagate 3TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST3000DM001)
- Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
Additional Options:
- LG WH14NS40 Blu-ray Writer Optical Drive 14X BDR
With this as as Pre-Order for when in Stock: ( Seperate Order )
- NZXT Hue+ RGB Dual Channel LED Controller - Black
