Titan 8100i Triceratop
30 Nov 2008
Ok need this pc for 3d studio max , after effects and ect should this do the job and what you think about the specs? cheers
Product Name Qty Price Line Total
"Titan 8100i Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Quad Core Gaming PC "Titan 8100i Triceratop" Intel Core i5 2500K 3.30GHz @ 4.40GHz DDR3 Quad Core Gaming PC
Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW)
Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD
NZXT Phantom Enthusiast USB3.0 Full Tower Case - White
MSI HD 7850 Twin Frozr III OC 2048MB GDDR5 PCI-Express Graphics Cards
Total : £1,312.16
Seems a bit pricey for a i5 and a 7850.
This should be better:
YOUR BASKET
1 x "Ultima 9650i Laser" Intel Core i7 3770K 3.50GHz @ 4.50GHz DDR3 Ivybridge Gaming PC £666.64
1 x Microsoft Office Starter Edition £0
1 x Sapphire HD 7850 2048MB GDDR5 PCI-Express Graphics Card £169.99
1 x 24 MONTH WARRANTY - COLLECT & RETURN £0.01
1 x Standard Build Systems - Approximately 5-7 working days £0
1 x Samsung 250GB SSD 840 SATA 6Gb/s Basic - (MZ-7TD250BW) £149.99
1 x NZXT Phantom 410 Enthusiast Midi Tower Case - White £94.99
1 x Seagate Barracuda 2TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST2000DM001) HDD £78.98
1 x No Operating System £20
Total : £1,201.61 (includes shipping : £17.50).
Will you be gaming on the machine at all?
YOUR BASKET
Thanks! yes i probs will be doing some gaming as well! as well as after effects and 3d studio max! will this suit all my needs and better then the one i picked?
Thanks
As above, try doing a self build, will be better all round and people will help you get what you want it to do, as above I would have thought the 3770k is miles better than the 2500k for what you want.
1 x Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £229.99
1 x HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card (H795F3G2M) £220.00
1 x Samsung 256GB SSD 840 PRO SATA 6Gb/s Basic - (MZ-7PD256BW) £189.98
1 x ASRock X79 Extreme4 Intel X79 (Socket 2011) DDR3 Motherboard £167.99
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £99.98
1 x NZXT Phantom Enthusiast USB3.0 Full Tower Case - White £99.98
1 x Samsung Green 16GB (4x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual/Quad Channel Kit (MV-3V4G3D/US) £77.98
1 x XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £69.98
1 x Alpenföhn K2 Mount Doom CPU Cooler (Socket 775 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £51.98
1 x LG GH24NS95 24x DVD±RW SATA ReWriter (Black) - OEM £17.99
Total : £1,242.36 (includes shipping : £13.75).
a lot more power i7, later LGA2011 socket, 16gb quad ram could make it 32gb tbh and a good overclocking cooler, ram over clocks well, sdd one of the fastest, can also cache 3tb one as well for more performance and a better vga card and still under budget for a self build :)
1 x Avexir MPower Series 32GB (4x8GB) DDR3 PC3-12800C10 1600MHz Quad Channel Kit (AVD3U16001008G-4CM) £143.99
Total : £1,308.37 (includes shipping : £13.75).
same as above with 32gb installed :)
rendering needs cpu power and ram, then a good openGL card to display, this has both, m/b supports 7.1 sound so no addon card needed, but can be added as there's plenty of free space, m/b does triple sli or crossfire so a new psu would be needed for another card but again it can be altered if needed.
sometime an i5 just doesn't cut the mustard, that's what i7 are made for, plus why go Socket 1155 when better is out, if you can wait then try the next one which will be out soon, but the LGA2011 will last longer than the Socket 1155 will do....
Thanks mate! so this should be the one for me! ? thanks
Total : £1,308.37 (includes shipping : £13.75).[/QUOTE]
