Below are OC’s overclock settings for my Titan Accelerator . The Core speed using CPUZ is 2016.8 (alternates to 3015.6 or thereabouts) and the multiplier is x6. Jduging by whats been written on the forums, getting the multiplier from x6 to x9 is the thing to do is it not! Any suggestions to tweak OC’s settings to at least establish a stable 3.0Ghz speed would be most appreciated. Stability is key for me as I am not really a gamer. Most of my time is spent with Adobe products.
Can't seem to work out how to put images in with my post!!
Ai Overclock Tuner - Manual
CPU ratio Setting - 09.0
FSB Frequency - 335
PCIe Frequency - 101
DRAM Frequency - 671mhz
DRAM Timings - Manual
CAS Latency - 5
DRAM Ras to Cas Delay - 5
DRAM Ras Precharge - 5
DRAM Ras Activate to Precharge - 18
All the rest set to Auto
CPU voltage - 1.45000
CPU PLL Voltage - 1.60
FSB Termination Voltage - 1.30
DRAM Voltage - 2.10
NB Voltage - 1.20
Loadline Calibration - Disable
CPU Spread Spectrum - Disable
PCI-e Spread Spectrum – Disable
Asus P5Q Mobo, Q6600 GO, Corsair 4GB PC2-6400C5, Antec 1200 Case, Vista Home Premium 64-Bit, two Seagate Barracuda 500GB drives, HIS ATI Radeon 4850, Corsair TX 650 psu, LG GGC-H20L Blu-Ray Reader, Samsung 22 inch Aqua monitor.
FSB Frequency - 335
CAS Latency - 5
DRAM Voltage - 2.10
NB Voltage - 1.20
