- 14 Dec 2010
- Nottingham
I am pasting this nvidia forum, so apologies if things in here were repeated in other threads.
Hi folks,
I installed my Titan on Friday, never really considered this throttling issue because I honestly didn't do enough research beforehand. I was just excited to get this thing installed. I previously used a Gainward Phantom 680 GTX.
I was scoring 10300 in 3D Mark 11 before (this use to be higher, newer drivers and Win 8 have dropped it 200 pts or so)
With the Gainward Titan installed I get 12800 which seemed a little low to me, so I did some digging.
Using Precision, it seems my clocks are pretty stable but the max stock boost was 1006 which seems low compared to others.
I did a small OC, set power to 106% and target temp 90C.
This card never goes over 80C regardless of what I set. It's like it's locked to a maximum of 80C.
When it hits 80C, checking the power in the monitor log it reads 100.000 and then spikes down to 70 odd. There is like random spikes to around this 70 figure, but the clocks don't seem to be effected.
I am just really confused about this temp target. It just doesn't work whatsoever after lots of testing over this weekend. Whether its set to stock, overclocked etc it will never go above 80C
Would someone like to have a look at my monitoring file during a Unigine Valley run and tell me what might be going on? (You can ignore the 836 clocks, I was in Windows with the browser open and typing this at the end.)
http://www.filedropper.com/titanstuff
Just the monitoring file, screenshot of Precision settings and bench result in Valley.
Help?
Hi folks,
Help?
