i bought the titan exodus from overclockers with the intel core i5 750 2.66ghz @ 4ghz. when i play starcraft2 beta it heats up to 60C isnt that bad? :S im using pc probe ii to monitor it. ive got the pre installed fans set to high but im thinking of getting two additional fans for the front of the case.
[05/25/2010 at 11:23 am] CPU Temperature Abnormal, 60 degrees centigrade
[05/25/2010 at 11:23 am] CPU Temperature become normal, 59 degrees centigrade
