Hi all
Thinking of replacing the fan on my Titan Fenrir with 2 Nexus PWM Series 120mm Quiet fans (already made an adaptor to fit another fan to other side of Titan Cooler )...and then replacing the exhaust fan on my Antec 902 case with the Titan fan ....connecting them all to a Akasa PWM splitter - smart fan cable AK-CB002
So basically i should have all 3 fans in a line pushing the air straight out the back of the case .....running off the cpu-fan 4 pin pwm socket on the motherboard and the splitter running of a power connector so not overloading motherboard .
What do think of this setup ? i would have thought it would work well as all the fan are running at same speed , roughly same cfm air flow for each fan (76cfm nexus / 78cfm titan) ,all in line and all fan are PWM .Also will be able to get rid of the case fan which is only controlled but 3 position speed controller which is hard to get to on mine as under a desk.
