- 16 Mar 2006
Hi,
I recently purchased an i7 and a Titan TTC-NK85TZ Fenrir cooler to go with it as the reviews of it were very good. However the temperatures I was getting with it were not very good with the i7 getting up to 90'C during 100% load on all 4 cores.
I took the cooler off to make sure that it was seated properly and it appears that the base of the cooler is far from flat. I have pictures that I will upload tomorrow, but basically, of the 4 copper heat pipes that go into the base, only 2 of them are actually making contact with the CPU, and none of the aluminium base is touching either. This explains why the cooler its self was hardly warm!
I have seen guides around on how to produce a perfectly flat finish, just not sure I'm keen on doing this and potentially messing up the cooler. I will call Overclockers tomorrow and see what they say.
I was wondering if anyone else has had a similar experience? And has anyone had any experience in making the base of coolers flat? Any good guides around?
Cheers,
Phil
Cheers,
Phil
